front hubs - Ford Powerstroke Diesel Forum
Old 04-30-2011, 07:51 PM
front hubs
Okay so my 4x4 works but not in automatic or whatever just in lock... i stalled it up one night in 4x4 and i heard a loud pop.... so now in automatic it pops real loud when in 4x4. but when i lock it up it works fine so are my hubs busted?? or
Old 05-03-2011, 10:00 PM
Sounds like you might have a bad hub. Last winter I had one hub slow to engage in snow and it popped when it engaged, ended up destroying my driver side hub. I ordered some warn premium manual hubs, they just got here today. It seems like this is a fairly common problem with them.
Old 05-05-2011, 10:52 AM
hhmm what about stock replacements lol... i hate having to get in and out now its such a pain lol
Old 05-05-2011, 11:10 AM
You can get some from ford. But IMO the strength of the aftermarket warns is worth the trouble of having to manually lock them every time. If you decide to stay stock make sure you pull them apart periodically to grease them. It will help them lock in and out easier
Old 05-05-2011, 01:49 PM
hhmm so the warn ones are that good??
Old 05-05-2011, 03:01 PM
Worth every penny and every time you go out and lock em in IMO. I just got back home from a trip and installed them in 10min. I have had them on several other vehicles and they never let me down. Honestly you see them side by side and you can tell how beefy the warns are compared to the fords.
If you do some searching on here lots of people have done the same thing.
Old 05-05-2011, 10:08 PM
If you decide to keep the stockers here is a link on how to lube/clean them.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
It will help with longevity.
Old 05-09-2011, 04:59 PM
Alright here is a question regarding the hubs. How do you tell if you have the automatic style hubs, as there is no print on them at all. There is vacuum style hoses running to the rear of the hub. Also is it normal for the front axles to spin going down the road in 2wd. Thanks for any answers, as I am still trying to figure out all this stuff that is new to me.
Old 05-09-2011, 05:09 PM
I WOULD CHANGE TO THE WARNS WELL WORTH THE MONEY I HAVE THREE SETS OF THEM NEVER BROKE ONE AND I DO TUG-OF-WAR WITH MY TRUCK WHEN I HAD THE STOCKS IN MY 2000 SD I BROKE BOTH AT THE SAME TIME CRAKING THEM DOWN THE CASE I WOULD HIGHLY RECOMEND THE WARN PREMIUM HUBS
Old 05-09-2011, 05:13 PM
IF THERE IS A VACUME LINE YOU HAVE AUTO OVER MANUAL ALOT OF GUYS TAKE THE LINE AND CAP IT OF BECAUSE IT CAN CAUSE PROBLEMS WITH YOUR A/C VENT NOT CHANGING BUT IF YOU DO THIS DONT FORGET TO CAP IT ON THE BACK OF THE KNUCKLE SO NO WATER GETS IN THERE AND DESTROYS YOUR WHEEL BEARINGS
