4x4 not working...electrical...
ok, i've read a lot about all this happening... but here it goes....
i have ESOF.... turn the knob... nothing works. no lights on the dash, nothing. So i've checked all of my fuses (all good) i've checked my transfer case motor (thats good) i've checked all of my relays (they are good) i tested out the plug that plugs into the xfer case motor... nothing. no power or anything... help. what can this be... with summer coming up and me pretty close to the outer banks, NC i want to get this issue fixed ASAP. |
did you check for power at the switch? do you have a scanner with the enhanced ford? I know mine will pull esof codes.
but no i havent actually checked it. |
Subscribed I have same problem!
Sent from my iPhone using Autoguide |
Ok, so I don't get any lights on the dash either, even though it engages.
Have you checked to see if the driveshaft is spinning? If it is then your hubs probably aren't locking automatically, and there is a vacuum leak somewhere. But I'm going to assume you've tried locking them manually. |
(funny way to find out your 4x4 isnt working literally 2 feet onto the sand on the beach and then all the sudden my 8,000ish lb truck is buried in sand... fail
bummppp.... anyone?
i've read enough on this forum to know many of you guys have the same problem...
i've been actively looking / trying to trace the wire back to the source |
Same problem here
subscribe.............
