ZF6 Breakage?
The rear housing on my 6 spd transmission has broken for the second time now. Any ideas as to what might be causing this? The housing is breaking close to the transmission mount. I replaced the mount the last time because it was worn out. I hoped that was what was causing the problem but it just broke again. I haven't been towing anything or putting the truck under any stress either. Any ideas would be greatly appreciated. Thanks. Tim
I accidentally posted this in the wrong place. Anyone know how to move this over to the transmission problems section.
Can you take some pics? Maybe you didn't have your thrust clearance right when you put it together last time.
Not sure what kind of pics you were wanting but here are a couple of the crack itself. It cracked in the same location last time. It is just in front of the transmission mount.
I'd just have it welded back up. Don't know what your problem is.
I'd check your engine mounts. The source might be further upstream of the transmission.
Well I've finally got the transmission out. The only problem I found was the pilot shaft bearing was worn out. Don't know if this may have been the cause or not. I really hope to find the problem before reinstalling it because it is not a cheap or easy fix. Thanks to everyone for their ideas.
I doubt that a piolot bearing would cause your problem since the crack is at the back of the case.
I read a service bulletin somewhere that was saying, If you remove your trans with the Xfer case still attached it can lead to tailhousing failure....Just an FYI
By adding stress to the weaker tailhousing
