anyone any good with front ends - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-02-2011, 07:01 AM Thread Starter
usnavyad's Avatar
Feedback Score: 3 reviews
hey all ok question i have a crazy chirping metal to metal scraping sound on the driver side around fast slight turns maybe 30-45 degrees this sound started right after i smoked a caliper and replaced it i just did ball joints and dust seal and all that on the passenger side any clues would be greatly appriciated
usnavyad is offline
post #2 of 14 Old 04-02-2011, 06:32 PM
codysweat's Avatar
maybe your race is spinning on your outer axle shaft is sounds nasty could also be hub bearings going out. i did my front diff did ball joints hub bearings outer axle shafts from yukno and all new seals races and bearings made a big difference.
1/30/98 EARLY 99 7.3 F350 DRW CC 4X4 4R100 3.73 LARIAT
codysweat is offline
post #3 of 14 Old 04-02-2011, 06:39 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Bent backing plate? Really the only thing you would have been around when replacing the caliper.
dhanna6powerstroke is offline
post #4 of 14 Old 04-02-2011, 09:03 PM
Oregon_Stroker's Avatar
Kind sounds like your wheel hub bearings. Jack up your front end and see if there is play with your wheel/tire. If it moves most likely the bearings. Mine went out and started off sounding like what you are describing, good luck.
Early 1999 PSD EXT CAB LB 4X4 Auto
6" lift 37" Toyo MT w/ 20in XD Addict wheels
TS Chip - 50,75,100,140,High Idle,Anti Theft
Triple Gauge Pod - EGT, Trans Temp, Boost
5500K HIDs
Riffraff Intake
5" Straight Pipe to 6" tip
Foil Delete
MAP Sensor Maximizer
Smoked Cab Lights
Bilstein 5100 series shocks
08 Rear Diff Cover
Viper 5901 system
Oregon_Stroker is offline
post #5 of 14 Old 04-03-2011, 01:43 AM Thread Starter
usnavyad's Avatar
I kinda figured herring what are these races I took it all apart before on pass sided and did not see any races I do know there was no on the driver side
usnavyad is offline
post #6 of 14 Old 04-03-2011, 04:55 AM
Feedback Score: 5 reviews
I would guess either hub or really warped rotor... is there a vibration too, or just the noise?
ToMang07 is offline
post #7 of 14 Old 04-03-2011, 04:57 AM Thread Starter
usnavyad's Avatar
No vibration at all there are some chunks gone in the back of the rotor from how ever long ago not to bad though
usnavyad is offline
post #8 of 14 Old 04-03-2011, 06:23 AM Thread Starter
usnavyad's Avatar
Boys im pretty stumped on this one would yall say its safe to just replace the hub berring and see if that works any now where I can get one at a good price its not the and one so I can save some cost there
usnavyad is offline
post #9 of 14 Old 04-03-2011, 06:24 AM
Mod Newbie
Quoted: 20 Post(s)
I hate throwing parts at vehicles but O'Reilly Auto Parts sells them for less that $125 here.
post #10 of 14 Old 04-03-2011, 06:30 AM Thread Starter
usnavyad's Avatar
I mean I have been driving the truck and nothing major I also hate just trying parts but i mean they go anyway so more good then bad right i hope its the shild rubbing the caliper
usnavyad is offline
