need 4x4 help again - Ford Powerstroke Diesel Forum
Old 03-25-2011, 02:49 PM
If it aint a CAT itsa DOG
need 4x4 help again
My 4x4 is still not right. First off i have warn lockouts and ESOF. When i have the hubs locked in and i hit 4hi it grinds like an SOB until i slow down and then it softly clunks in, BUT even after its in 4hi when you are cruising down the road it still grinds. Its worse when you back off the throttle. Now if i unlock the hubs and hit 4hi i don't hear any grinding at all! That shouldn't be, it should grind like heck because the front end isn't spinning to match up with the rear end. I am assuming that something is fawked up in the t-case. ANyone else ever ahd this happen too or think of anything else to check?
Old 03-25-2011, 03:25 PM
Anyone, bump this up.
Old 05-03-2011, 05:10 PM
Winning DUHHH
You have it backwards, When your locked in your front wheels are spinning the front axles, and differential, and driveshaft the same speed as your moving. And when you unlock them, your wheels are spinning freely, and the Axles, differential, and driveshaft arent moving until you try and click it into 4 wheel. It almost sounds like your T-Case isnt times correctly....If that even matters, OR you have a worn out synchro or gear.....Im leaning towards a mechanical failure at this point
Old 05-04-2011, 05:41 PM
I know sometimes i run on in posts, but if you read my post its not backwards. Obviously when the hubs are UNLOCKED the axles and shafts aren't spinning but thats when if i try to lock it in it doesn't grind at all. Even though the t case is spinning while moving in 2wd. In my old truck with a manual t case, if you tried to pull the lever into 4x4 while the hubs were unlocked it would grind until you stopped moving. With the hubs locked in you could pull it right back into 4x4 at any speed. Only difference is on my new truck i have an electric motor doing the switching instead of a manual lever.
Old 05-05-2011, 01:44 PM
Winning DUHHH
Well, IDK then. I have WARN Manual lockers on mine. Regardless of the hubs being locked/unlocked. Nothing grinds.
I just went and tried it.
