Hub lock replacement or full hub replacement? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-07-2011, 08:58 AM Thread Starter
Pardon my ignorance, but I've yet to replace anything on the front end of my truck. When you jack the front end up and the tire wiggles a bit, is it the hub lock or the entire hub assembly that needs replaced? I've wanted to swap over to the fully manual hubs for awhile but not sure exactly which one to put on...i.e. warn, dynatrac or other various brands. Also, when would the full blown hub free spin kit be neccessary to put in?
I don't care about cost, I care about longevity and not breaking at the most crucial times!
2002 Ford Excursion 7.3 Powerstroke
AFE Stage I intake
4" straight pipe exhaust
Superchips Flashpaq
Wicked Wheel
VSS 6" lift w/305x 70 R16's ProComp All Terrains
omega17632 is offline
post #2 of 4 Old 03-07-2011, 09:08 AM
66Bronco's Avatar
Depending on mileage, it's probably ball joints.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #3 of 4 Old 03-14-2011, 07:05 AM
cghoerichs's Avatar
If you have big tires and your truck is jacked up your hub assembly, not 4x4 hub, is probably going.
Mulberry Grove Family Farm
2002 7.3 4x4 C1 Axle
Warn Premium Manual Hubs
cghoerichs is offline
post #4 of 4 Old 03-18-2011, 12:02 AM
depending on which way it wiggles, it could be ball joints, tie rod, or wheel bearing, your 4x4 hub has nothing to do with it, best idea is to jack it up, and have someone wiggle it while you check for movement
matter is offline
