Vibration- LIFTED TRUCK - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-15-2011, 03:00 PM Thread Starter
livnlrn's Avatar
Need a little help. I have an 8'' lift on the truck in my sig. Cant get rid of vibration. Trying to figure out the combo. between carrier bearing drop and shim in the rear springs. I know I need ladder bars, but I'm trying to get my driveline angles right before I install ladder bars.
2001- F350 crew cab
8'' pro comp lift
38-15.50-18 Mickey- mtz
autometer pillar guages
volant intake
zoodad mod
4'' mbrp exhaust
dp chip
itp boost fooler
hpx line
superlift truspeed
JW valve body
livnlrn is offline
post #2 of 20 Old 02-15-2011, 03:21 PM
107stroker's Avatar
Quoted: 2 Post(s)
Thumbs up
i ended up having to go with a one piece driveshaft in rear to get rid of my vibration 100%. i shimmed the rear diff and the carrier bearing drop 10,000 different ways and could not get it all out. the one piece rear with a dual cv did it. ladder bars definitely to stop the axle wrap.
107stroker is offline
post #3 of 20 Old 02-15-2011, 04:04 PM Thread Starter
livnlrn's Avatar
I was thinking of a 1 piece shaft, but my local shop said it might be to long of a distance. Who made your shaft?
2001- F350 crew cab
8'' pro comp lift
volant intake
zoodad mod
4'' mbrp exhaust
dp chip
itp boost fooler
hpx line
superlift truspeed
JW valve body
livnlrn is offline
post #4 of 20 Old 02-16-2011, 06:51 AM
107stroker's Avatar
Quoted: 2 Post(s)
got mine at the driveshaft superstore. high angle driveline makes good ones as well.
post #5 of 20 Old 03-06-2011, 07:21 AM Thread Starter
livnlrn's Avatar
Ordered shaft from Driveshaft Superstore. It should be here in a week. Hope this fixes vibration. I will post the results when I get it.
2001- F350 crew cab
8'' pro comp lift
volant intake
zoodad mod
4'' mbrp exhaust
dp chip
itp boost fooler
hpx line
superlift truspeed
JW valve body
livnlrn is offline
post #6 of 20 Old 03-16-2011, 11:53 AM Thread Starter
livnlrn's Avatar
Thanks for the info guys. I put the new driveshaft in, & it fixed all my problems. Wish I would have did this sooner
2001- F350 crew cab
8'' pro comp lift
volant intake
zoodad mod
4'' mbrp exhaust
dp chip
itp boost fooler
hpx line
superlift truspeed
JW valve body
livnlrn is offline
post #7 of 20 Old 03-16-2011, 12:02 PM
Freedombyforce's Avatar
So this takes care of the take off shutter vibration from zero to 20 mph or so? I've only got a 4" lift but its still pretty bad. Was this a custom length driveshaft or did driveshaft superstore have one already made and ready? And one last ?.... how much $ did you drop on it?
Thanks a bunch!
2002 F-250 CCSB
ZF-6 Swap
Manual T-Case Swap
K&N Intake, CCV Dumped, Riff Raff Boots
Foil Delete, AIH Delete, EBPV Delete
Wicked Wheel
Farm Boy's 5" Straight Pipe with 6" tip
PHP's Tunes with 6 pos
Hutched 51 gal Titan Tank
Iron Bull Bumper with PIAA 510's and Strobes
Warn M12000, Retrosolutions LED's inside and out
2011 Tailgate -Taillights - Front Ford Emblem
17" Fuel Octanes with ProComp Extreme AT 35's
Freedombyforce is offline
post #8 of 20 Old 03-16-2011, 12:13 PM Thread Starter
livnlrn's Avatar
This was a custom built shaft. It only took them a week to make it & have it at my door. The driveshft looks awesome. They do good work, & are very good to talk to. It cost me 450.00. U should b able to lower ur carrier bearing enough to fix ur problem. When I had my 6'' lift, I had no problems at all.
2001- F350 crew cab
8'' pro comp lift
volant intake
zoodad mod
4'' mbrp exhaust
dp chip
itp boost fooler
hpx line
superlift truspeed
JW valve body
livnlrn is offline
post #9 of 20 Old 03-16-2011, 12:14 PM
KING of BLING!
ExtremeFord4x4's Avatar
It solved all my vibes too. I'm glad you got it straightened out. And I guess that is why the 2011's now have a one piece.
2005 Ford Excursion 4x4 Limited(Current)
2006 F350 Crew Cab 6.0 Lifted 6",22's,SRL, Edge CTS(Totaled)
2003 F250 Crew Cab 6.0 Sonic Blue Sport 38s/20s(SOLD)
2001 F250 Crew Cab 7.3 w/ 08 Clip 37s/22x14s(SOLD)
2005 Excursion Limited 6.0 I.D. Tunes 38s/20s(SOLD)
2008 F350 Crew Cab 6.4 Job II 2.5" Leveling kit(SOLD)
2001 F250 Single Cab Short Bed Looney Tuned 6.0 Conversion Studded/EGR Delete(SOLD)
ExtremeFord4x4 is offline
post #10 of 20 Old 03-16-2011, 12:19 PM
The truck actually has a carrier bearing block for an 8" skyjacker lift. I left it on there when I went to the 4". I wonder if to much shim could be giving me a problem?
2002 F-250 CCSB
ZF-6 Swap
Manual T-Case Swap
Wicked Wheel
