Broken 2 Peice Shaft Again.. - Ford Powerstroke Diesel Forum
Old 02-05-2011, 03:02 AM
First Off. My Truck Is E99 Supercab LongBed 6SPEED, 158WB? Lifted With A 2" Or 4" Block In The Rear(Center Currier Shimmed, CC Bearing Was Also Replaced Couple Months Ago)
I Broke A Bolt On One Of The U-Joint Straps On The Rear Axle(Again...2nd Time) (Tore The Rear Piece Right Off) i was towing a vehicle up a incline in 4th gear(50-55MPH) about 10-14 PSI Boost. And It Broke And Shot The Driveshaft In The Freeway. (Everyone is fine, and no damage under the truck besides a nice mark on my gas tank)
my question is why do i keep snapping the bolts(getting tired of welding new ends on the tube and Balancing) Or What Kind Of MGR should i buy the strap kit from(was not more then 2 months old/5k miles) or should i go to a one piece shaft
i mostly do city driving, not much towing and average highway time. ideas will be considered.
i payed 200$ last time, im fine spending more money to get it right and not have to do it again. Ill Post A Picture Of It Soon
Old 02-05-2011, 03:08 AM
Send a message via AIM to tonypagnano
i would just get a spicer strap kit and make sure to torque the bolts going into the yoke you sould be fine
Old 02-05-2011, 03:10 AM
i had spicer and did torque the bolts down, thanks for the reply
Old 02-05-2011, 03:13 AM
when you say you tore the rear piece right off do you mean you like ripped the straps off? im assuming if you have it balanced somewhere they obviously have it phased right....
Old 02-05-2011, 03:17 AM
it didnt like rip them off, one bolt broke then the u-joint twisted out of the other one. just dont know how i keep breaking such strong bolts?
