Replacing trans output shaft seal & diff seal as well - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-18-2011, 03:10 PM Thread Starter
jwink's Avatar
My Zf is leaking from the output shaft as well as my differential output shaft seal, I picked up both seals today. Whats they procedure for replacing both of these. I know i gotta pull the driveshaft, and then i'm thinking that the seals somehow slip out with some encouragement?? This is for a 2001 f350 extended cab dually long bed. Will i lose a lot of fluid out of each when doing the job?
I'm a student and live in an apartment complex but i have a good set of tools so i figure i can get it done in a few hours.
Thanks,
Wink
2001 F350 SC dually, six speed, Diy Intake, Isspro Boost and Pyro, Casserly stage 1's, CCV Mod, AIH and Foil delete, non-ebpv pedestal, diy high flow outlet, 05 headlight conversion, Recon smoked fender and cab lights!
Proud member of the Fighting Texas Aggie Class of 08'!
jwink is offline
post #2 of 4 Old 01-18-2011, 03:20 PM
Bad Night's Avatar
Quoted: 3 Post(s)
The hard part is the getting the yoke off of the pinion . The bolt is tightened to 470ft lbs . Then the yoke is pressed on . It's no fun at all .
07 F-250 Outlaw , Rough Country 6 inch lift , 37-13.5 R20 Nitto Mud Grapplers , MBRP 5" Exhaust , 08 Mirrors , S&B intake , 5% Tint sides and back , 35% windshield .
Bad Night is offline
post #3 of 4 Old 01-20-2011, 09:36 AM Thread Starter
jwink's Avatar
Is it really that difficult? I have never removed a driveshaft, i thought that you just had to remove the 4 u joint bolts and give the driveshaft a tap with the hammer and it will come off the tailshaft of the transmission. I need some advice ASAP going to try and tackle this this afternoon.
jwink is offline
post #4 of 4 Old 01-20-2011, 11:05 AM
Bad Night's Avatar
Quoted: 3 Post(s)
Pulling the drive shaft is easy . It's replacing the pinion seal that is tough .
