Rear Axle leak.......HELP......!!!!!!!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-23-2010, 08:36 PM Thread Starter
ford99's Avatar
I have a 99 f250 4x4 and my rear axle seal in leaking...because it is all over the inside of my tire...i just woundering how u got bout changing it the easiest way to fix it...thanks
ford99 is offline
post #2 of 5 Old 12-23-2010, 08:47 PM
ryandamo's Avatar
its not hard at all, pop the rotor off, you then pop the axle off by removing the 8 bolts holding it in and pry it out. then you are going to have to rent or but the 4 prong hub nut removal socket. you pop the hub off being careful not to drop the wheel bearing on the ground. Then you take a seal remover or a big screwdriver and pry the old seal off the back of the hub and evenly press the new one in., then you just put it together. Be sure to tighten the hub nut to the factory spec and you may as well replace the oring on the axle shaft while you in there.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 5 Old 12-23-2010, 08:58 PM
dnf12908's Avatar
Quoted: 25 Post(s)
What you might try first is clearing your axle tube vent line. What commonly happens is this line gets plugged with sludge or dirt and causes the axle to pressure up and force oil out the seals. Sometimes it's the pinion seal, sometimes the axle seal, or both. You need to pull the rubber tube off the fitting on the axle tube and clean it out with a drill bit and also blow the rubber line out with air. I had a major oil leak on my axle seal recently. I cleared the vent line and the leak stopped. Hope this helps.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #4 of 5 Old 12-23-2010, 09:02 PM Thread Starter
ford99's Avatar
thanks for the help guys
ford99 is offline
post #5 of 5 Old 12-28-2010, 03:38 PM Thread Starter
ford99's Avatar
what is the part number for the 4 prong socket...???and what is the factory spec for the hub also...???
ford99 is offline
