Transfer Case Locked In 4x4
I was out today and needed to put in 4x4, it went into 4x4 normally and when i went to take it out it wouldn't respond, I put it in neutral and also shut trk off but still it didn't help. So I put it in low 4x4 and it also went in but now its stuck in 4x4 low, I've tried everything and it won't function, I've ck fuses and switch and there is no noise coming from actuator motor on transfer case. So if someone could point me in the right direction I would appreciate it I think it possibly could be a relay for high/ low operation of transfer case just not sure where to start.
AJ
you have an automatic switch or a manual shift???
if yours is an auto switch, just pull off the wire harnesses going into the t-case. spray them down with some circuit cleaner, make sure you connection is good and i think that will help your problem. i assume it is an auto switch, however if not than you need a new t-case haha |
Go underneath and find the transfer case actuator motor. Gently smack it with a hammer and block of wood. The key word here is gently. This worked on my 97 Expedition when the 4x4 would not engage. Good place to start before bringing out the wrenches. Hope this helps.
AJ |
I sure like the look of your truck. Did you do the pin stripe and gray accent stripe yourself or was it like that from the factory? I have a 06/cc/sb, black and have been thinking about dressing it up a bit. Any hints would help. Hope you get the 4x4 system working without breaking the bank.
Graeme |
Did you ever figure anything out? My dads truck is stuck in 2wd with no motor shift noise.
I had ck everything I could and including those relays mentioned below vvvv we'll see how does all winter, I'll keep you guys posted if it acts up again I think its in the circuit board of the motor that tells it where to stop at the correct position IMO Quote:
