4x4 slow to engage/disangage with warn hubs - Ford Powerstroke Diesel Forum
Old 12-11-2010, 12:26 AM
Hello. I have had warn hubs on my 2002 xlt with electric 4x4 switch for about a year now. It use to work great, went to use it today and it took about 5 min to get the 4x4 light to come on and engage. Now it wont come out of 4x4. Any ideas.
Old 12-12-2010, 08:53 AM
Bad motor on the transfer case probably.
Old 12-12-2010, 04:00 PM
Thanks for reply, I swaped the motor over and still no go. I then removed one of the relays by the side of the fues box an found a wire had broken. So i am about to go and mend it , finers crossed that is the main problem.
Old 12-12-2010, 04:12 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
If not try getting a manual transfer case and put the shifter on the floor. Then you will never have an issue.
I have a floor shifter. That is a must in any truck I ever buy.
Old 12-12-2010, 06:47 PM
All fixed. Just a broken wire. Thanks guys
Old 12-18-2010, 10:26 AM
Can you post a pic of the relay and broken wire you found as I'm having a similar problem, put it in 4x4 and it will not go back out then put it in low range and stayed stuck there its driving me batty.
Thanks
AJ
Old 12-18-2010, 08:05 PM
here you go. If you look there is a red conector just under the relay box, This is were it broke.
Old 12-19-2010, 04:15 AM
Thanks for picture but mine doesn't have that set up, yours must be different year mines a 2002 and the fuse box is under the dash I think I'm going to start running continuity test on wires around t/c motor and see if theres a problem somewhere.
Thanks Again
AJ
