Front driver side clicking - Ford Powerstroke Diesel Forum
Old 11-21-2010, 08:29 AM
i have a 99 powerstroke crew cab, when i roll the window down i can hear a clicking noise coming out of the driver side tire area when i am driving, to me it seems like a wheel bearing but they usually dont click like that and there seems to be no slop in tire, what do u guys think?, or what all should i be checking to narrow down the problem?
thanks
Rick
Old 11-21-2010, 10:16 AM
The ft bearings are a pair of ball bearings in an assembly. Unlike regular tapered bearings you won't feel any slop until they're completely destroyed (you want to replace them before that happens... )
So, it could absolutely be ft brgs, it could also be something in the tire so give that a good look! Just like a axle brg in the rear, a "clicking" noise can indicate a bad brg..
If you jack-up that side and push the pads back into the caliper, to stop the brake & rotor from influencing the feel, you should be able to feel a bad brg.. It might have a bit of slop but, more importantly, it will have bad spots you can feel while rotating.
You could also compare it to how the other side "feels"....
Your truck is over 10yrs old, if they you've got normal mileage and they're the original brgs., chances are you need them by now
