steering vibration and pulling to the passenger side - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-20-2010, 07:26 PM Thread Starter
STLstroker's Avatar
I have never encountered this problem since i have owned the truck the past 5 years. The truck has wheel vibration at about 45MPH and jerks the steering wheel back and forth a little bit. I have to aim the steering wheel towards the left because it pulls hard to the right side if i let go of the wheel. At highway speeds i don't feel much vibration in the wheel but the pulling to the right gets worse. As long as the truck travels straight i feel nothing. I have no idea what to think about it. Wheel allignment or wheel out of balance?
Luke
99 F-350 7.3 turbo diesel ext cab 4x4
All terrain tires
Hypertech Power Programmer III
Hurculiner on entire bed
Tonneau cover
fog lights
4" Straight turbo back exhaust
DIY Tymar Intake
wastegate delete
ISSPRO triple pod guages
Much more wanted but $ plays a big factor in college
STLstroker is offline
post #2 of 6 Old 10-20-2010, 08:39 PM Thread Starter
STLstroker's Avatar
anybody have this sort of problem before?
Luke
All terrain tires
Tonneau cover
fog lights
DIY Tymar Intake
wastegate delete
post #3 of 6 Old 10-21-2010, 06:23 AM
Rockyardjo's Avatar
Right front brake hanging up? Next time it does this, stop and check to see how much heat is building up on that hub.
2000 SCSB 4x4--6 speed manual--4" turbo back
DIY intake--DP F5 chip--ebpv exhaust brake--ISSPRO gauges--CCV Mod--ELC coolant+filter
If local and need scan, I have AutoEnginuity
Rockyardjo is offline
post #4 of 6 Old 10-21-2010, 07:05 AM Thread Starter
STLstroker's Avatar
Ill give that a look and see. I would almost say the allignment is off but i haven't hit a big curb or anything that i know of that would really knock it off. Sitting at a stop when i try to put the steering wheel straight it quickly flings back to about "10 o'clock" once i let go of the wheel. Or if i have the wheel at 10 o'clock to go straight and let go going about 5mph the wheel starts shaking and pulling to the right at about 2 o'clock. I only feel a lot of vibration at lower speeds. The wheel jerks back and forth a little bit at lower speeds, but gets better once i hit about 60mph
Luke
All terrain tires
Tonneau cover
fog lights
DIY Tymar Intake
wastegate delete
post #5 of 6 Old 10-21-2010, 01:35 PM
Fishhook240's Avatar
Get the truck alignment checked. Just had mine done and was having the same problem except I was at 2 o/clock A couple hundred $ later and 2 alignment bushing and everything cool Straight wheel and straight down the road
Live as if it was your last Day!!! "AMEN"
Fishhook240 is offline
post #6 of 6 Old 10-21-2010, 02:29 PM Thread Starter
STLstroker's Avatar
Yea im going to have to get that done. I am have tempted to wait a little bit til I have the money for new tires.
Luke
All terrain tires
Tonneau cover
fog lights
DIY Tymar Intake
wastegate delete
