Possibly bearing noise? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-17-2010, 07:29 AM Thread Starter
Fireman40's Avatar
I getting a kinda of roar from what i think is the front end. Its not the typical bearing roar though. Just last year I replaced both hub assemblies cuz the needle bearings were shot. Now i know i can replace just the needle bearings. anyway i did the hub test and locked the hubs and i still get the noise. I even put it in 4x4 and still get it. I only hear it in the cab and a slow speeds of 25 and slower. I guess the motor is to loud otherwise. But IF i hold me head out the window i cant hear it. only in the cab. I have not had a chance to pull the hubs assemblies off and check. I did pull the locking hubs and there is no rust dust inside which i had last time. any ideas?
2012 F-250 Crew Cab LB 4x4 OFF ROAD
BONE STOCK
Fireman40 is offline
post #2 of 5 Old 10-26-2010, 05:57 PM
bigcaveman's Avatar
Send a message via Yahoo to bigcaveman
I have the same issue. Got a question for you though. Did you replace your whole hub assembly or can you break them down and re lube/replace bearings? I am going to tear mine apart on thursday but cant seem to find anything as far as the break down in the Ford Pub. Thanks in advance.
Shawn
'99 F-250 4x4 Supercrew
TC leveling kit
315/75/R16 BFG A/T
DIY Intake
Straight Pipe
Gauges
Crossover tube
Stacks Inwk...
More to Come.......
bigcaveman is offline
post #3 of 5 Old 10-26-2010, 06:05 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
Oh boy, this sounds just like my 03 6.0. I had it at 2 different shops to try and find the bearing noise and nothing. I had replaced BOTH wheel bearings, brakes, hubs, and tires with NO change at all. Last place said it was roaring in the whole driveline from the trans back to the rear end. Funny part is mine would get worse when you turn the wheel or get quieter going the opposite way. Have you checked u joints/carrier bearings in the rear?
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #4 of 5 Old 10-28-2010, 01:49 PM Thread Starter
Fireman40's Avatar
You can replace the carrier bearing in the hub the carries the axle shaft. I had not done this myself but I have heard many say it can be done. If you search the threads hard enough someone out there has the ford part number for it. I have taken both hubs off and checked them. Everything is good. I have check the locking hub assemblies and the axle shaft. I still get this noise. I can only hear it a low speeds and it doesnt make a difference when I hit the brakes. My options now are to check my u joints and drive shaft carrier. Does anyone have any tips on what I should look for? Are there any dead giveaways that I have a bad u joint or carrier bearing?
BONE STOCK
post #5 of 5 Old 10-29-2010, 09:03 AM
I had this same issue with my wife's Dodge and after replacing the front wheel bearings and the noise still there I got underneath and checked the U-Joints. Unfortunately you can't feel if the needle bearings in one of the caps are shot without taking the shaft out. Well, I did so and sure enough the front joint had one cap with no grease with few needles left in it. Replaced the U-joints and noise was gone.
SCOTTSF250 is offline
