Whats wrong with my rear end? - Ford Powerstroke Diesel Forum
Old 10-10-2010, 08:58 AM
I changed the gear oil, added the friction modifier, when accelerating while turning at low speed, like pulling out of a drive way onto the road I get for lack of a better description I get a womp womp womp, and I can feel a vibration. Is the limited slip going out or is the whole rear end going? Its got 152,000 miles on it. Any help is greatly appreciated
Old 10-10-2010, 01:14 PM
u add motorcraft lsd add?
Old 10-10-2010, 02:33 PM
I used Valvoline synthetic gear oil, it said that you dont need to use an extra additive, so I ran it for a while and noticed the womp in the rearend so I went back to NAPA and picked up there friction modifier, put it in and it still does it
Old 10-10-2010, 02:35 PM
Ill go to Ford tomorrow and pick up there additive, should I drain and refill the diff or can I add the Ford stuff along with the stuff thats already in there?
Old 10-11-2010, 07:48 AM
I'd drain and refill with what FoMoCo recommends.
Old 10-11-2010, 01:03 PM
I put the Ford additive in it and it still does it. I hope I didnt wreck anything by not running it for about 2,000 miles with the NAPA additive
Old 11-11-2010, 05:55 PM
I have the same problem in an 01 with 159000 on it, Changed with valvoline syn, put additive in, same problem, Everything looked great when i pulled my diff. cover off...
Old 11-11-2010, 06:04 PM
Same here . Just did this a couple months ago . Added friction modifier to the valvoline and it still does it . I figure it trashed the clutches in the ls. pack .
Old 11-11-2010, 06:15 PM
NOT a Democrat
Sounds like you guys did take out the clutches in your diff. I did this in an 88 Mustang. Same thing, It was fine until I changed the fluid.
Old 11-12-2010, 05:32 PM
man, i figured this was the problem, but didn't want to hear anyone agree with my thoughts! ha, whats the cost usually to replace the limited slip setups in these? I have put detroit lockers in my muscle cars that i know are reliable, but they cost me upwards of $750 just for the parts!
