2000 F250 6-Spd Clutch Shutter In Reverse - Ford Powerstroke Diesel Forum
Old 10-08-2010, 10:54 AM
I have a 2000 F-250 with a 7.3 and 6sd trans. I recently had the clutch pack and clutch petal hydralics replaced by my Ford dealer. I pull a 7000lb 5th Wheel behind my truck. After the clutch change I haven't been able to manuver the truck in reverse especially at sharp angles or up any kind of incline or hill without a lot of clutch chatter. Everything works find in the forward gears. Anyone have any ideas as to what the problem might be? Thanks in advace........
Old 10-08-2010, 08:37 PM
i think chatter is normal.. it is a big clutch, mine chatter in all gears but just at idle and when its loaded
Old 10-16-2010, 02:22 AM
dont know if the chatter your talking about is more like lunging cause thats what mine does(lunges) in reverse on slight inclines. i was told it is due to a warped flywheel
Old 10-16-2010, 02:46 AM
Mine has apparently fixed it self............... Dealer says may have needed to breakin a bit......who knows. Thanks for taking the time to respond........
Old 10-18-2010, 06:46 AM
When I had my Southbend installed the shop owner said to put the truck in 4 low when backing. I told him I have plenty of power and he said "it is alot easier on your clutch because your not feathering the pedal and slipping the clutch".
