4 LO won't work - Ford Powerstroke Diesel Forum
post #1 of 39 Old 09-12-2010, 11:55 AM Thread Starter
If it aint a CAT itsa DOG
dieseldan2005's Avatar
4 LO won't work
The 4 lo won't engage on my truck. 4 hi works fine, but when you put it into 4 lo you can hear a clunk in and then out and the 4x4 light goes out and you can't put it into 4 hi even until you shut the truck off. Dealer told me it was the t case motor when i bought it. Well i replaced that today with no luck. Looks like i am gonna make them reimburse me for that one. What the heck else is causing this? ESOF switch? I have a p1867 code that comes up on my AE. Also where are relays number 40-41? Are those right next to the under hood fuse panel? Manual won't show the location of them. It just says what they are.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #2 of 39 Old 09-12-2010, 04:16 PM Thread Starter
bump this up
Diesel Dan
post #3 of 39 Old 09-14-2010, 11:12 AM
Rowe80013's Avatar
I'm curious to see what cames of this.. My truck takes a long time for 4Lo to engage but eventually goes in every time. Good luck
99' PSD extended cab, long bed, 4x4, 6 speed. 4" custom built exhaust system with MBRP downpipe. EBPV disconnected. Southbend Organic clutch/solid flywheel. Goodyear Wranglers.
Rowe80013 is offline
post #4 of 39 Old 09-14-2010, 11:22 AM
SuperCrutyPS's Avatar
Quoted: 312 Post(s)
Garage
K - This may be a silly question, but here goes. You are stopped, putting the truck in Neutral, stepping on the brake and then flipping the ESOF switch right? I'm sure you're smarter than me, but the reason I ask is that I learned that the hard way. I would be rollin' along and switch to 4-Hi, which would work. I would do that for 4-Lo - No Go. AFTER I read the owner's manual, did I find out the right procedure.
Beyond that, aren't there vacuum line that run to the front hubs? Could they be leaking, not allowing the hubs to lock? Throwing it out.....
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #5 of 39 Old 09-14-2010, 02:47 PM Thread Starter
Thanks for double checking on the proper procedure. I know it can easily be over looked. Ok well here is what i have found out so far. Took it back to the dealer and they said its a broken wire somewhere in the whole fricken harness! So now i have to tear through the entire thing to find the broken wire.
Diesel Dan
post #6 of 39 Old 09-14-2010, 08:00 PM
Quoted: 312 Post(s)
Garage
Well that blows. Good luck in finding that.
My Truck Garage:
Tow Toy Garage :
post #7 of 39 Old 09-25-2010, 01:46 PM Thread Starter
Gonna bump this up again. Another dealer said its in the t case. Well i can manually put it into 4 low with a crescent wrench. It goes in and out just fine. I bought yet another shift motor and tried cycling it to 4 low with the motor off the t case and it does the same thing, won't hit 4 low and all 4x4 lights go off on the dash. I am still convinced that it is in the wiring somewhere. Don't know if its in the relays or GEM. Anyone else have some more input? 2nd dealer also pulled codes p1820 and p1828 along with the p1867 code that i got. This is driving me crazy guys!
Diesel Dan
post #8 of 39 Old 09-25-2010, 07:20 PM
scotty2280's Avatar
bump for ya dan
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #9 of 39 Old 09-25-2010, 07:22 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
did you replace the switch?
i need a new one. sometimes it wont turn on unless i wiggle the knob.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #10 of 39 Old 09-25-2010, 07:23 PM Thread Starter
Thanks man, not too much help on here anymore. Anyways, i think i am gonna look at the relays tomorrow and still consider the neutral safety switch. I am going to bring it back to anderson's on Monday if they have time to look at it.
Diesel Dan
