Truck swaying like crazy in the rear please help
Truck swaying like crazy in the rear. I can't find the problem. I have replaced upper and lower ball joints, u-joints, in both sides in the front, , checked the rear shocks, steering shock, put new tires on, Truck is not lifted 2000 f-250 4x4 I'm going to change the front sway bar end links tomorrow. Has anyone had this problem? It sways like a race car on slicks with low air pressure. It is scary to even drive it. Please help! Thanks
Its probably the end links. Do you have a rear sway? if not consider getting one..
I don't have a rear sway bar. Anyone know where I can get on cheap?
Junk yard..30mm one to get. have good shocks?
Replace tires recently?
Have you checked the spring bushings? Axle U-bolts still there? Lug nuts tight? Cab bolts? Do you have vinyl seats? Armor All them lately? Hearing any clunks when the truck sways? What brand and size tires did you put on? What pressure are you running? Are you absolutely sure you don't have a broken spring? Check all the leaves in the packs.
For the record, only one question was smart assed.
sway bar end links did not fix the truck I replaced the tires already here is a link to the tires I bought Fierce Attitude M/T Tire Details
Did it do it after the tires? I've seen issues with tires...feels like the truck is so (excuse the NASCAR term) loose you can't keep it straight.
Steering box possible. I was ready to drive mine off a cliff before I replaced it
swaying before the tires and after the tires. Theirs no play in the steering wheel. Just if you turn the wheel right then left the truck sways bad in the back.
