Pretty sure U joints - Ford Powerstroke Diesel Forum
Old 09-02-2010, 02:21 PM
Pretty sure it's my U joints that are out. Regardless, with 300K original miles I wanna do em anyway. The PROBLEM is idk how to do it
I've looked up online but only found ball joint procedures. I've dropped the drive shaft before and reinstalled fine. I've also got a Ford repair manual CD and it tells me but it's not entirely clear. Just wanted to check with you guys first.
Old 09-04-2010, 08:34 PM
you need to strip everything down till you have just the steering knuckles, before you can remove the axle shafts, its also a good idea to replace all 6 seals at this time, the yellow o-ring for the wheel bearing/hubs, the big wheel seal/axle seal, and the dust seal/small wheel seal, you will need to make your own seal driver to install the axle seal, not very hard to do, some write up for the ball joints, shows how to make one
Old 09-05-2010, 08:00 AM
umm I've got a 2wd
Old 09-06-2010, 11:54 AM
oh, i was thinking the u joints on the front axle, drop the drive shaft, and use a flat head screw driver or needle nose pliers and pry out the little spring on the outside ear of the yoke
Old 09-06-2010, 11:55 AM
http://arrc.epnet.com/autoapp/8828/8...d_U_Joints.htm
Old 09-26-2010, 05:36 AM
Hey Dude, I need to do this on my 4x4. I have the seale & the uj's but how the hell do you get the old seals off & the new ones on at the uj end of the shaft?
Old 09-27-2010, 12:06 PM
Matter........excellent link! I bookmarked it I've done them on my FJ40, but it is a flange deal, not a yoke. If anything, these should be easier. It does mention the matchmark which is very important. I also mark the slip yoke just in case it comes apart.
