truck wobble need help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-13-2010, 12:02 PM Thread Starter
ok i noticed my truck was feeling loose when driving first let me explain everything that is new then i will go to problem ok upgraded hubs to dynatrac free spin all new both hubs are working great new tie rod ends both sides and i replaced u joints and cv yoke bearing as well so only other thing i could think of was ring and pinion so i have noticed that i can turn pinion on truck about 3/8 to 1/2 left or right but no up or down or side to side play so my question is does it sound like i need new pinion bearings? or just need to be re sheamed? i talked to a guy today about it and he said i would have to get new ring and pinion and full install kit but i dont see why i just did a lube job on rear diff and ring and pinion look fine and spider gears look fine.
so anyone got a clue?
oh almost forgot to mention that when i stop at a stop sign or something to that affect when i give her the pedal it feels like it takes a sec or 2 for truck to go.
dixiedevil is offline
post #2 of 3 Old 08-13-2010, 12:29 PM
KING of BLING!
ExtremeFord4x4's Avatar
Is the trac bar loose? Wouldn't hurt to check it. Death wobble is mainly caused by trac bars.
2005 Ford Excursion 4x4 Limited(Current)
2006 F350 Crew Cab 6.0 Lifted 6",22's,SRL, Edge CTS(Totaled)
2003 F250 Crew Cab 6.0 Sonic Blue Sport 38s/20s(SOLD)
2001 F250 Crew Cab 7.3 w/ 08 Clip 37s/22x14s(SOLD)
2005 Excursion Limited 6.0 I.D. Tunes 38s/20s(SOLD)
2008 F350 Crew Cab 6.4 Job II 2.5" Leveling kit(SOLD)
2001 F250 Single Cab Short Bed Looney Tuned 6.0 Conversion Studded/EGR Delete(SOLD)
ExtremeFord4x4 is offline
post #3 of 3 Old 08-13-2010, 01:29 PM Thread Starter
hey
nope trac bar is cool i belive this afternoon i am gonna jack front of truck up and recheck front wheel bearings just in case everything in new in the hubs but you never know i might have not tightned the spindle nut enough my main concern is the pinion play not sure if it should have that much slack.
