Knowledgable and Experienced powerstrokers..HELP! - Ford Powerstroke Diesel Forum
Old 08-02-2010, 02:48 PM
Ive spent hours and hours searching forums for an answer to my problem but everyone elses fix, doesnt fix my truck..........here goes
My truck makes a loud pop/thud when turning(mostly left) and especially if Im turning left and go thru any kind of dip or bump. Also, the initial pop is almost always followed by another one when I turn the wheel back straight as if the first pop is something that is put under a tension and then the 2nd pop is like the binding tension is relieved. The pop/bang is being transmitted right into the floor board where the drivers side rear shackle is directly under my feet.
Ive crawled under my truck dozens of times now looking for something loose or worn or making contact with something else. So far my efforts to eliminate the noise to no avail have been......
-replaced all 4 ball joints.
-replaced the leaf spring silencing plastic between the leafs
-checked shock mounts and tightened
-checked drag link and track bar. Retightened everything
-checked tie rods. Theyre not extremely tight, but I cant get any actual play out of them.
-sprayed wd40 on leaf spring eyes where they mount to shackles(no change in sound)
-disconnected sway bar and no change
PLEASE, ANY IDEAS WOULD BE GREATLY APPRECIATED! Im running out of ideas.
Old 08-03-2010, 02:27 AM
Noone has any ideas?
Old 08-03-2010, 02:58 AM
Retired Soldier!
I was having the same type of sound right under my feet when I turn. I changed the drag link and track bar. It started when I put new springs on the front, I had a broken one on the driver's side. The springs I put on were leveling springs and they raised it up 2 inches. I have 85,000 on mine.
Old 08-03-2010, 09:30 AM
Leaf spring bushing? check that sounds like mine was doing its a B to change
Old 08-03-2010, 01:06 PM
How did u check the leaf spring bushings? My spings themselves look good so I dont think thay one is broken.
Old 08-03-2010, 01:22 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
sway bar endlinks
Old 08-03-2010, 01:28 PM
have to get under the truck and check everything. i could see rubber hanging out and shinny metal but i had to look a few times b4 i got it. I changed out the swat bar bushing and still had the knock. But i have a fab-tech lift and its prone to that. and it was a B to change. i had to take off the spring and bring it in. the bushing have to be pressed in. just get under there and take a good look at everything in the area.
Old 08-03-2010, 04:08 PM
Thanks, Ill check them out.
Sorry I forgot to mention that I also checked the sway bar end links. (added)
Old 08-04-2010, 01:16 PM
ARMY MOM!!!!
Send a message via Yahoo to korg70kbc
Originally Posted by dereku View Post
sway bar endlinks
mine were missing the bushings but onl ade noise occasionally.
edit, sorry saw u checked those. already...............
