Anyones auto hub lock stopped working? - Ford Powerstroke Diesel Forum
Old 07-10-2010, 12:24 PM
Just wonding how common it is for the auto hub locking function to stop working on these trucks. I'm need to get new center caps for my M/T classics II wheels and I'm considering getting some dome's on all 4 wheels which would cover up the manual hub locks on the front. I don't use 4wd much only in the winter time, truck is an 03 with 78K. What's everyone's opinion?
Thanks.
Old 07-10-2010, 12:43 PM
O.I.F. Combat Vet 11B
If you the auto is not working the you def don't want to cover the manual hubs lockers up. It could be many things that have stopped your auto hubs from working. Start withe looking for a vacuum leak somewhere on the system. Start with the driver side hub and go from there to see if you have any broken lines that are leaking and go from there.
Old 07-11-2010, 05:31 AM
Sorry, maybe I gave the wrong impression. My auto hubs still work perfectly. I was just wondering how common it is for them to malfunction and if it would be foolish for me to cover them up simply just for looks. Thank you for the info though, maybe someday it'll come in handy.
Old 07-11-2010, 05:39 AM
Almostdunfukinwidit
Its really common for the 99-03 auto hubs to stop working due to vacuum leaks
Old 07-11-2010, 05:43 AM
I wouldn't cover mine up. why would you want to?
Old 07-11-2010, 05:46 AM
2002 Excursion my hubs wont turn should I do the warn conversion or test my vac lines next?
Old 07-11-2010, 06:28 AM
Depends on if you have couple hundred bucks burning a hole in your pocket or not. More than likely it can be fixed with finding a simply vacuum leak. Or it could be a leaking o ring inside the hub. I just went ahead and did away with the auto hubs locks and went with warn.
Old 07-12-2010, 02:08 PM
hubs
The hubs are froze up wont spin and all my vacume contolled stuf are working fine Must be hubs ya think?
