Banging under truck
Ok guys Im feeling something banging under the truck. I can feel it really strong under my left foot when im driving. Im assuming its something to do with the front suspension/steering and is transferring the vibration through the shackle on the leaf (right below my left foot)
I've crawled under the truck a few times and tried wiggling things, nothing seems to be moving. Any ideas? |
check your sway bar and end link bushings ...
hope its that. thatd be easy.
thats what is wrong with mine, just havent got around to fixing it. quick test is disconnect the swaybar links and zip tie them up and out of the way, if it goes away that is your problem.
Or just crawl under the truck grab the sway bar and shake it up and down, if there is any loose i can almost guarantee you that is what your problem is !
my 2000 F250 was doing the same thing...turns out the lower bushings in the front shocks were bad.
Do you live close to the border?
Mine is doing this also. I checked everything and finally assumed it had to be a ball joint since everything else was tight. Well I changed all 4 and its still banging and popping everytime I turn the wheel and when I hit a bump while turning also. Tie rod ends?????
Plz help |
loose body mount...
wheel bearings for sure if you havent replaced them.. mine were completely shot at 140,000
