Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 05-16-2007, 04:10 PM
chopstx667 chopstx667 is offline
Send a message via AIM to chopstx667
4X4 not engaging right
Today I put my truck in 4-HI and have all the hubs engaged on auto. It rolled forward normally but then when the 4x4 light came on, it felt like it was pulled back. I felt like if I were to press on the gas pedal, it was going to push against a rod and break or something. I then tried to put it back in 2WD and it still was the same way. I even tried putting it in reverse and in neutral and everything. I was stuck that way for a good 5 minutes before I turned off the truck and then restarted again. By then it was ok and drove with out any problems. Any idea guys? Not real experienced with the 4x4.
Old 05-16-2007, 07:19 PM
bump, anyone?
Old 05-16-2007, 08:38 PM
Logan Logan is offline
The Fat Mod
Hum, that is strange. What gear did yo uhave it in when you first tried it? Do you have the floor shifter, or the flip switch?
Old 05-16-2007, 08:55 PM
I just put it in drive and tried to move. I have the flip switch on the console.
Old 05-16-2007, 09:01 PM
The Fat Mod
how fast were you moving? I like to sit still if at all possible. Also, sometimes, it takes a little time for things to line up. Have you tried it since?
Old 05-16-2007, 09:34 PM
I was completely stopped on the side of the road. Reached over to put it on 4x4 and then it happened.
Old 05-16-2007, 09:38 PM
The Fat Mod
Thats really strange. Maybe Marc or one of the other techs will chime in here in a bit. It should go in while rolling. Did you have the hubs locked manually? Try that and see what happens when you do it again.
Old 05-16-2007, 09:45 PM
Yeah I always read posts about people automatically engaging 4x4 so I decided to see if mine could on the "auto" setting on my hubs. I haven't tried manual yet but it'd be nice if I didn't have to run out and change my hubs everytime I needed to race someone lol.
Old 05-16-2007, 09:56 PM
The Fat Mod
Yeah, if your hubs are not locking properly, it is probably the vac lines. You can see if they are cracked at all. If they do not engage all the way, that can cause problems. Lock them in manually, and see what happens.
Old 05-16-2007, 10:04 PM
I will try again tomorrow and let you guys know. How do I check the vac lines?
