overdrive flashes - Ford Powerstroke Diesel Forum
Old 05-24-2010, 04:05 PM
overdrive flashes
overdrive goes on and off does anyone know what it could be
Old 05-24-2010, 06:02 PM
bump. anybody?
Old 05-25-2010, 05:34 AM
Are you talking about the Overdrive Light?
The OD light on the stalk is kind of like what your "Check Engine Light" is for the motor.
Only it flashes when there are codes present showing problems for the transmission.
Something's wrong in there, get it scanned with a good scanner or take it to a trans shop.
Old 05-25-2010, 06:41 AM
I had a 2000 model that had developed a short in the wiring. The light would randomly go off and on. If your light is flashing continuously its a warning signal.
Old 06-09-2010, 01:45 PM
where was the short?
Old 06-22-2010, 06:51 PM
when does it start flashing, mine only does it in park, as soon as i shift into drive, i'm fine, (neutral safety switch) easy fix about 30 bucks for the part too..... good luck
Old 06-22-2010, 07:22 PM
Mine flashed towing my fiver up a long hill on a hot day in Idaho almost a year ago to the day. The 4R100 AT does not like heat, the stock tranny gauge only reads hot when it is way, way too late, and the stock tranny cooler is inadequate. My 2 cents: Check your fluid and replace if even only halfway bad, and for future reliability install a good tranny oil cooler and a Magnefine filter in line ahead of it. The clutches in the tranny disintegrate under high heat stress and will clog the cooler without the Magnefine. There are fancier setups for cooling and filtration but the greater cost brings diminishing returns, IMHO. That's what I did and I've been fine since. Parts and info at dieselmann's Store: Transmission
It also could be wires chafing in the steering column. You can tell if it is overheating or a wiring issue by the conditions under which the flashing occurs.
Good luck!
