front axel?? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-30-2010, 12:32 PM Thread Starter
Exclamation front axel??
New to this truck plz help.. I was replacing my hubs with warn hubs. Driver side went fine everything is tight.. The passenger side threw me a curve ball Seems like the axel shaft is way loose. I can push it in and pull out like a 1 1/2 to 2 inches. What would be the cause of this is there a clip inside the pumpkin to keep the axel from sliding out or something else. also i know i have to replace the axel seal because its tore up from te shaft flopping around and now its leaking fluid out of my diff.. Never done an axel seal on one of these and dont know whats causing the shaft to slide out so far any help would be appreciated and a list of parts needed to do the axel seal would be a help thk brian
99 f350 stoker crew cab dually 4x4
rebuilt trans(ford rebuild)
straight piped
diy intake
mods wanted
4inch exhaust
6.0 trans cooler
6.0 inter cooler
guages
chip
08 mirrors, tailgate
05 conversion
fordboy84 is offline
post #2 of 2 Old 05-02-2010, 07:51 AM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
Here is a good writeup on how to replace balljoints. You need to remove the axle when you replace balljoints so this will give you a good step-by-step on what to do. You just won't have to do as much. Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
2002 f-250 4X4 XLT 7.3,
stock tranny
DP-Tuner F6 chip
mbrp ss 4" turbo back exhaust
diy intake with zoodad mod
3 pilllar guage setup with autometer guages Thanks Raul
valve body
boost fooler
NEXT ON LIST
torque converter
pinkfloyd is offline
