Rear wheel bearings - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-16-2010, 01:02 AM Thread Starter
powerstroketom's Avatar
Rear wheel bearings
Hello. I have been trying to work out why my truck vibrates when i put power down and i put it back to my rear wheel bearings, How do i change these and were can i get the bearings. I am just about to replace the front two and thought a would do all four at the same time. I cant seem to find much info on the rear. Help
powerstroketom is offline
post #2 of 6 Old 04-16-2010, 06:32 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
You mean Axle Bearings?
I would first be sure ALL my U-Joints were good before I thought about a "vibe" under power being caused by wheel bearings....
NoRalPh is offline
post #3 of 6 Old 04-16-2010, 01:26 PM Thread Starter
I have checked all my u js and they all seem fine. I can grab my rear right hand wheel and pull on it and i get a clunking noise and a bit of movment.
post #4 of 6 Old 04-16-2010, 02:59 PM
Quoted: 157 Post(s)
You mean In & Out?
NoRalPh is offline
post #5 of 6 Old 04-16-2010, 08:07 PM Thread Starter
yer. I just checked my u js again and your spot on. i have the rear one starting to go. one of the caps is cracked.
post #6 of 6 Old 04-16-2010, 09:08 PM
ford_trck's Avatar
Send a message via AIM to ford_trck
You can get the wheel bearings and wheel seals at any auto parts store. You will need a special socket to take the hub nut off though.
Early 99 F-350 CC LB 6-speed
Stock with mods
Originally Posted by CloverLeafFarm View Post
Hey Ross, after talking with you i did some research and seems like you chose the right path to go, i knew you were a super genius!
Ross
ford_trck is offline
