2WD Rotor install - Ford Powerstroke Diesel Forum
Old 03-31-2010, 05:49 PM
2WD Rotor install
I had to replace my front wheel bearings this evening. I cannot get the rotor on far enough to put the nut back on the hub. Do these things have to be seated a certain way or what? I'm stuck.
Old 03-31-2010, 07:00 PM
Old 04-01-2010, 04:45 AM
Old 04-01-2010, 05:29 AM
Sounds like the bearing races might not be in all the way. What kinda truck?
Old 04-01-2010, 05:32 AM
Did you put a new seal? Is it the right one?I've not had any problems w/mine just put little grease on seal & shoulder of spindle that seal should slip over. Did you put a new race in rotor & it is set all the way?Maybe you got wrong seals, only things I can think of.
Old 04-01-2010, 06:15 AM
The bearing is in the cup as far as it can go. It is an 03' F250 7.3 2wd.
Old 04-01-2010, 06:18 AM
Yes I put a new seal in, it matches the old one so I don't think it's the wrong one. I've never done this so I'm not sure if you're supposed to bang it in or what? I always thought it should just slide rite on.
Old 04-01-2010, 08:30 AM
You should not have to bang it I always just make sure & put a little grease on seal kind of feel it line itself on spindle and push it on. Wiggle the rotor a little as you push it up on spindle.If everything you changed is same as you took off it should slide right on,good luck CJ
Old 04-01-2010, 09:54 AM
I just realized that I didn't get a race. Napa told me that I don't need one? But a mechanic just told me the rotor will not go all the way on if I didn't install a race? haha. What the he!!?
Old 04-01-2010, 10:29 AM
Just curious, did you buy new rotors to put on? If you did and the clowns that sold you the rotors or bearings didn't say anything about the race I think I would find a better place to deal with.I have always been told to put a new race when you put new bearing they wear together.
