Transfer case motor and ESOF - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-12-2010, 03:40 PM Thread Starter
Does the GEM have to get a response from the transfe rcase motor before it will move the motor?
I have replaced the GEM and the relays and still nothing. No clicks lights or nothing?
tdnp is offline
post #2 of 4 Old 03-12-2010, 05:43 PM
The indicator lights come from the GEM,mine won't come on until I hear the case shift-then lights up.
Did you check the motor on trans. case-may be locked up-pretty common problem.
Hope this helps!
icysmooth is offline
post #3 of 4 Old 03-14-2010, 11:12 AM Thread Starter
any one know what the voltage to the 86 pin of the relays is suppose to be?
tdnp is offline
post #4 of 4 Old 03-16-2010, 07:15 PM Thread Starter
Ok for any that are following. FIXED tonight with the help of Jarrod B from these forums. He posted to another thread(HELP HERE PLEASE! 24 views and NO ONE KNOWS?) some wiring diagrams and after tracking down the connections found two broken wires, fixed them fixed the problem. changed all the parts back to the original and all works great. So if anyone is looking I have a brand new GEM.
Thanks to Jarrod b I saved a truck load of money, pun intended
tdnp is offline
