Rearend code?????? - Ford Powerstroke Diesel Forum
Old 03-11-2010, 02:36 PM
Rearend code??????
The rearend is going out of my truck (2000 F-250 4x4 7.3PSD) and everyone is asking the axle code. The tag is gone and I have no idea what it is beyond a 3.73 gear with a posi-type locker. Any ideas on what code I should be looking for?
Old 03-11-2010, 03:11 PM
I think if you look at the data tag on the door post, where it says axle, there should be a # or set of letters.
Old 03-11-2010, 03:15 PM
The door post just say 3 letters, but everyone is looking for a number and letter combo.
Old 03-12-2010, 02:25 PM
Is there any real difference in a gasser rear vs. a stroke?
Old 03-12-2010, 02:39 PM
probally just the ratio. Do you not have a tag on the rear end cover??
Old 03-12-2010, 02:42 PM
Go to the dealer and get the as built data.
Old 03-12-2010, 02:43 PM
No, the cover had been replaced before I bought the truck. When I have called some of the wrecking yeards, they say that there are 7 different codes for 3.73 rears in 2000.
Old 03-12-2010, 02:46 PM
Had not thought of that. I will see if they can help. I know that it is not drivable at this point. The housing is worn where the bearing had been spinning on it. I put a set of bearings in hoping that I could prolong the death, but it is still making the rumbling sound. I am sure it is just a short time from breaking the housing.
Old 03-19-2010, 12:07 PM
This may help..
What is my Ford rear end ratio, do I have positraction - Drivetrain.com
