another Auto Hub Issue/Question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-08-2010, 06:32 PM Thread Starter
I am having the same issue with mine.
I put it in 4h or 4L and it wont engage the hubs, unless i put the hubs on manual. So I read the thread, i took the hose off of the nipple that is on the spindle housing, I turned the key on , turned it to 4h and i can feel the line sucking. I put a vacuum gage on it, and its pulling about .75inches to 1in/lb. not sure if thats enough or not. But thats what i got, I then took the nipple out blew it out, it was already clean. did this on both sides.I checked for vacuum at the nipple side of the hose near the hub, its sucking, I checked vacuum right at the pump and its sucking also. I did the drive down the road in 4h and my defroster IS NOT still blowing. I read in the thread that the O-rings on the HUB themselves might need to be changed, so im going to get them. Is there another seal that might need to be changed(inner hub seal or or something?) I replaced my ball joints in Jan. 2010, Is there a seal on the axle that might need to be changed? or ? any other things to try?.. I checked all my lines they all seem to be good. and also i did the vacuum pump test, where i turned the key on and let the vacuum pump run, and it eventually turns off, so im assuming its holding pressure in the vacuum resevior.I know my solnoid on the transmission is engaging i can hear it.
Is there a way to tell if the hubs are bad or not? I read the link about cleaning them and greasing them up, is there a way to tell if the diaphram is bad in the hub? Not sure what else to check. When i turn the hubs to manual they do work. it will engage the front end. I dont really want to goto aftermarket hubs, I have center caps that have no holes them to access the hubs, unless i cut them not really at that stage yet. would rather fix what i have.
2000 F250 4x4.
Any help is appreiciated.
thanks,
2000 F250 Crew Cab 4x4
6" Fab-Tec Lift on 35" BFG's.
rufaast is offline
post #2 of 12 Old 03-08-2010, 06:44 PM
smokenstroke's Avatar
Quoted: 8 Post(s)
Bump for ya!
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
smokenstroke is offline
post #3 of 12 Old 03-08-2010, 09:24 PM
Zaairman's Avatar
Quoted: 12 Post(s)
You should have replaced the yellow O rings on the bearing assemblies when you did the ball joints. And I think you need more than 1lb of vacuum for the hub, but I could be wrong. The hubs are crap at best. Time for some Warns.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #4 of 12 Old 03-08-2010, 09:26 PM
choupique108's Avatar
i have a leak and i cant find it anywhere. Ive done changed everything on the d@mn thing and nothing works. I have some factory lockouts for sale. I have 2 sets
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #5 of 12 Old 03-13-2010, 06:58 PM Thread Starter
Has anyone changed the valve that the hubs and the vacuum pump connect to.
Im not getting any vacuum to the hubs at all, Also checked to see if i am getting any vacuum out of the check valve that is mounted on the passenger fender well. Im not getting anything out of it. Has anyone changed this valve before? Im guessing its a check valve not sure what its called.
I put new o-rings on today, on the hubs, and the hub assemblies, also serviced the hubs to, took them apart and cleaned them.
checked all my vacuum lines and found nothing wrong with any of them, no cracks or leaks , blew compressed air thru them to make sure they werent stopped up, but still no vacuum at the hub.
any one?
rufaast is offline
post #6 of 12 Old 03-13-2010, 07:30 PM
BGJ
BGJ's Avatar
My hubs have worked so far, but I must admit that it takes a few tries some times to get it into 4L. I miss my obs when it comes to this little plastic knob.
How difficult is it to install Warns & about how much cost?? Thanks
02 F250 Leveling kit, 295/70/17 Nitto Terra's
39501 miles on the clock
BGJ is offline
post #7 of 12 Old 03-14-2010, 09:37 AM
Zaairman's Avatar
Quoted: 12 Post(s)
any one?
I have replaced that valve and actually will sell you mine (slightly used but works) if you're interested since I switched to Warns.
It takes 15 mins to do both sides and the regular ones are $185. If your auto hubs still work they're worth more than that on eBay.
Zach
SLAPS Member #153
Zaairman is offline
post #8 of 12 Old 03-14-2010, 03:41 PM
BGJ
BGJ's Avatar
Good to know, thank you. I thought half of the problem was the device that shifts the transfer case. Am I wrong? I thought it was an electric motor. Really don't know. Just read about guys not being able to get it in or out of
4wd. BGJ
BGJ is offline
post #9 of 12 Old 05-24-2010, 06:15 PM
JMM_MD's Avatar
I put it in 4h or 4L and it wont engage the hubs, unless i put the hubs on manual. So I read the thread...thanks,
Did you ever get this resolved? I am having the same thing on a 99 250, I put it in 4X4 or low and I hear the transfer case "engage" but unless I manually lock the hubs no 4-wheel drive.
JMM_MD is offline
post #10 of 12 Old 05-26-2010, 03:20 PM
Quoted: 2 Post(s)
i second the warns. i replace all my vac stuff, i bought the warn premiums and they take only a second to install (the lockring is the only confusing part, had to scratch my head for a second. just have to spread it apart and pust it in there)
nismofan240 is offline
