2 -vs- 4 Wheel ABS. - Ford Powerstroke Diesel Forum
Old 02-28-2010, 08:55 PM
2 -vs- 4 Wheel ABS.
Familiar with identifying front ABS, but is there a simple method of determining 4 wheel ABS?
Old 02-28-2010, 09:28 PM
What year is your truck? Moist of the Ford trucks either have Rear ABS or 4 Wheel, so If you have ABS up front, you should have 4 wheel...
Old 03-01-2010, 02:21 AM
ROLL TIDE ROLL !!!!!!!
Look on your rearend if it has a the speed sensor right there then yes you technical have 4 wheel abs. It just compares front wheel speed to pinion speed and adj from that. Been a few years since I worked in a ford shop but this is how I remember it working. If im off here someone will chime in and call me out on it lol.
Old 03-01-2010, 05:21 AM
Calling you out on it. I have the speed sensor in the rear and no front ABS. It's nice in the snow, sucks everytime else.
Old 03-01-2010, 05:36 AM
Per another post, sounds like front ABS means 4 wheel ABS. Thanks for all the input!
Old 03-01-2010, 05:42 AM
Dang it Let me refrase that if you have front abs then your rear sensor is on the axle
