HELP HERE PLEASE! 24 views and NO ONE KNOWS?
02' F-250 4x4 automatic ESOF
First off my trans-and transfer case was destroyed about a year ago due to the front driveshaft coming apart! I had a used trans and transfer case installed for $2500. But never installed a front driveshaft! I installed a new front driveshaft. When I turn the ESOF switch on there is no lights in the dash! Also what kind of voltage should I be getting at the transfer case shift motor? And how do I check it? I would think one makes it go one way and the other back? Any help help would be great! Relays? Also I had the fuse pannel replaced a while back. thanks in advance for your help ! |
ok to start off, the transfer case motor is plugged in and the fuses are good?
yes....new fuse pannel and fuses, on the 02 is there any fuses under the hood?
The Transfer Case Shift Relay is located on the left hand side of the engine compartment, next to the Power Distribution Box.
^^ thats from my manual when you switch it from 2wd to 4wd, do you hear the motor kick in? |
there is 2 boxes by the brake booster. One has two of the same relays in it. and the other has one like those 2 and 2 small ones? which box is it?
the plug that hooks to the transfer case motor- orange and yellow wires. should there be power there? and if so which one? with the ESOF swith on 4hi or 4lo I didnt get any.
heres a pic of some of the harness. im still looking on the wiring details
http://i498.photobucket.com/albums/rr349/franklin24401/99F150DASH.jpg?t=1229440899[/IMG]
pic still doesnt work. to answer your question eariler, no i dont think theres suppose to be power to the transfer case since it is just engauging the device.
I'm thinking that the transfer case motor is likely the problem?
