NO 4x4 light in the dash and 4x4 doesn't work.
02' F-250 4x4 automatic ESOF
First off my trans-and transfer case was destroyed about a year ago due to the front driveshaft coming apart! I had a used trans and transfer case installed for $2500. But never installed a front driveshaft! I installed a new front driveshaft. When I turn the ESOF switch on there is no lights in the dash! Also what kind of voltage should I be getting at the transfer case shift motor? And how do I check it? I would think one makes it go one way and the other back? Any help help would be great! Relays? Also I had the fuse pannel replaced a while back.
thanks in advance for your help !
