Carrier Bearing/Bushing?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-04-2010, 07:56 AM Thread Starter
over200's Avatar
Quoted: 5 Post(s)
Where the short drive shaft out of transfer case meets the short connection shaft of the rear drive shaft is that called the carrier bearing?...Mine looks to be seriously worn out I can move the shaft up & down...The rubber looks all cracked up and there are 2 clamps just dangling around.....What all is involved in replacing?
Thanks
Howard
2000 F350 CCLB 536 k+ miles still runs like a top!
Diablo chip, quickie pedal, valve body, Air Force One air intake, MBRP system, XD Diesels w/ MT ATZ's, KL5H Train Horns / Air Zenith supplied.
over200 is offline
post #2 of 12 Old 02-04-2010, 08:07 AM
symbols's Avatar
Yes, that's it. You'll need at least a 3/4" drive breakover bar w/cheater pipe and a vise to get it off. I can't tell you how many 1/2 sockets and bars I broke trying to get the nut off. I even broke my vise that day That nut laughed at my 1/2" impact and the whole ordeal cost me about $500
New vice $200
New 3/4" breakover bar $70
New 3/4" socket set $200
Showing the drive shaft who is the boss....priceless
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #3 of 12 Old 02-04-2010, 08:18 AM Thread Starter
over200's Avatar
Quoted: 5 Post(s)
So your saying the actual part itself only $30?
over200 is offline
post #4 of 12 Old 02-04-2010, 08:28 AM
symbols's Avatar
I honestly don't remember how much the carrier bearing was.
Jason
symbols is offline
post #5 of 12 Old 02-04-2010, 08:29 AM Thread Starter
over200's Avatar
Quoted: 5 Post(s)
Ok..Thanks!
over200 is offline
post #6 of 12 Old 02-05-2010, 02:48 PM
Mine's starting to look the same way,are you getting an up and down kind of shake between 40-50 mph at lite cruising speed?
icysmooth is offline
post #7 of 12 Old 02-05-2010, 02:51 PM
no-tel-in's Avatar
I just did mine, I bought the whole carrier bearing setup from napa for around 100
yes the big nut is a ***** to get off, but my impact was able to get it off, other than that its pretty straight forward... I did ujoints during this time as well
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #8 of 12 Old 02-05-2010, 02:51 PM
wriott
Guest
Posts: n/a
Quoted: Post(s)
i just use an air hammer to get it off....
post #9 of 12 Old 02-05-2010, 03:02 PM Thread Starter
over200's Avatar
Quoted: 5 Post(s)
Yes....I bought the u joints also...might as well do it all since they are all original.....260k on them..I had to order the boot for the mating shaft that was just gone only remnants left are the 2 clamps hanging there
over200 is offline
post #10 of 12 Old 02-05-2010, 03:22 PM
Well-looks like I'll be ripping mine out and replacing it after this 30" snowfall that's starting to hammer my area is over and cleared out,thanks !
