..........no 4x4............. - Ford Powerstroke Diesel Forum
Old 01-15-2010, 04:37 PM
No 4x4, replaced transfer case motor,starts out 4hi switch to 2hi then back to 4hi nothing,new transfer case motor good. get codes p1866 c1728 p1828 p1820 p1867. Any help would be good.
Old 01-15-2010, 05:17 PM
Send a message via Skype™ to excursionMark
u sure the problem is in the t-case and not in the diffs ... did u manually lock the diffs nd try it because the auto locking vacuum stuff isnt the best thing in the whole world lol
Old 01-15-2010, 05:23 PM
manual lock.........no vaccum
Old 01-15-2010, 07:15 PM
im not sure what it could be then but ill give a bump hopefully for someone who does
Old 01-15-2010, 08:06 PM
Does that circuit run through a relay?
Old 01-18-2010, 08:17 PM
The Dash 4x4 switch send a signal to the GEM computer which then switches the 4x4 relays. The 2 relays are mounted under the hood next to the fuse box.
Old 01-19-2010, 03:32 PM
............replaced g.e.m. module tonight{those things are not cheap} still no 4x4?????LAKETROTTER how do you check a relay????????? THANKX FOR THE HELP.....
Old 01-19-2010, 03:46 PM
So you can lock the hubs and have 4x4 or not?
Old 01-19-2010, 03:51 PM
best way to check a relay is swap it with a known good one.
Old 01-19-2010, 03:53 PM
.............no 4x4.......do not lock hubs flip switch to 4hi .......nothing....no dash light
