another 4wd problem....not engauging ..stuck
Stuck in snow...4wheel drive not working...m/t baja mtz's didnt help..
4 hi and low lights come on in dash.. hubs turn into lock freely.. but they are deffintly not engauging..only back wheels spinning..it was in 2 ft of snow and friends with other psd's were motoring right thru it..micky t's were just packing with snow.. dug it out and its still not working..it was working a month ago and i dont know if it could have effected it but i drove thru a flooded 2-3ft of salt water since... anything i shuld try first? fuse or relays? Best way to check hubs, driveshaft, or transfer case? Thanks, im a 4x4 noob |
Sounds like you may have water in the hubs that froze and is preventing a lock. If it is water it will ultimately ruin the bearings.
sometimes vac operated locking hubs just stick. Some years (not sure if all ) also had manual hubs. If the automatic doesn't work, just turn the center lock mechanism and you have 4wd. My 01 has it. A local 4wd shop said he had never heard of that. I had to prove it to him.
They are manual lock hubs, no auto switch..
Switch says 2wd 4hi and 4low.. When it is in 2 wheel the front driveshaft spins free.. When i put it in 4x4 and lock the hubs, the driveshaft is locked.. |
do you mean the auto lock factory hubs have been replaced??
ive never heard of auto locks either if you have the manual locks. Didnt think you could have both at the same time. why would you need that. I just figured when you lock your hubs then its like pushing another diff until you put the tcase into 4hi or lo. Am I wrong on that
sorry for confusion...factory manual lock hubs
if your truck has a switch on the dash then you have autohubs BUT they only work when going to 4hi i believe. the auto hubs can also be used manualy though.
it sounds like to me that you have a broken hub |
huh interesting have to look at the cd and see how all that works but I dont have it on my truck anyway. Never been a fan of them. When you need them they dont work. LOL
"when you need them, they don't work" .. Beenuseing mine for 5 years .
When you select 4wd hi or low, the t case motor engages the tcase to the frnt driveshaft and the auto hubs engage. You can manually engage the hubs but if the t case motor does not engage the t case then you still don't have 4wd. They both have to work. |
