2000 f350 transfer case problem, help !!!!! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-08-2009, 03:38 PM Thread Starter
as of right now i still dont have 4x4, i turn the key on and then select 4hi, i can hear the transfer case motor run, then click, run then click, run then click. i still dont have 4x4. does this sound like i have something broken? any help would be great! also, do i need to take it in and have it changed or is this something i can do on my own if it is the motor, thanks again.
snopro442 is offline
post #2 of 9 Old 12-09-2009, 07:18 AM
Mine did the same thing. I pulled the motor off (3 10MM bolts, 2 connectors...easy) and took it apart. The gears inside were chewed up/missing teeth. Motor itself still worked, but would not turn the gears. Bought a new one from Napa.
Hopefully that's your only problem.
Mine still isn't right, either I got a bad motor or have bent shift fork in transfer case or something as it will go into 4 hi and low, just won't come out.
Good Luck and like I said, changing the motor out is easy.
Will
2001 F250 CCSB Lariat 4X4
7.3 PSD, 4R100
wsigo is offline
post #3 of 9 Old 12-09-2009, 07:28 AM Thread Starter
do i need to take it in and have anything reprogramed? i thought i read somewhere that i need to have the gem redone, thanks
post #4 of 9 Old 12-09-2009, 12:00 PM
I thought I'd read that, too. I asked either here or dieselstop.com and was told NO for a reprogram.
Maybe someone who really knows for sure can chime in and turn the light on for us!
Will
7.3 PSD, 4R100
wsigo is offline
post #5 of 9 Old 12-09-2009, 03:43 PM
UPDATE--- There is NO "reprogramming" necessary, but you need to get trouble codes cleared. These will not make the check engine light illuminate, and you won't be able to read or clear the codes with a standard OBDII scanner. Read below-
Since my Napa shift motor came with a 1 year warranty, I went ahead and swapped it out today. On the instructions, at the bottom in BOLD letters it says to NOT engage the motor until you have the ATC trouble codes cleared using the proper scan tool.
I installed the new motor there in the parking lot, and drove down to Ford. (making sure NOT to engage four wheel drive, of course)
After explaining to the tech the situation, and referring him to the instruction sheet, he hooked up the snazzy laptop/code scanner to my truck. He found multiple codes in regards to the transfer case and shift motor. He cleared the codes, now my four wheel drive works flawlessly. I was charged nothing. Your results may vary.
Good Luck snopro442 I hope this helps you!
Will
7.3 PSD, 4R100
wsigo is offline
post #6 of 9 Old 12-09-2009, 03:48 PM
Raul@Stealth Automotive's Avatar
i have one of those OEM motors here in stock that i was going to use on my own truck but never did... they are over 580 new.. make me an offer
-Raul
Raul@Stealth Automotive is offline
post #7 of 9 Old 12-10-2009, 05:00 PM Thread Starter
Thanks for all the help, I will be installing it friday and then I will take it to the dealer to have the codes removed, I will post an update later next week.
post #8 of 9 Old 12-10-2009, 05:05 PM
i wonder whay the codes needto be clearedto have the 4w work again? Also why would it hurt the new motor ifyou dont?I believe you guys here. Just wondering why or how?
melmount is offline
post #9 of 9 Old 12-15-2009, 07:16 PM Thread Starter
replaced the motor and had the codes cleared, they came up with 3 different codes all 3 came from the transfer case problem, works great, ready to go!!!!
