replacing front wheel bearings - Ford Powerstroke Diesel Forum
Old 12-05-2009, 12:57 PM
I was just wondering how to take apart the front hub assembly to replace the wheel bearings? Its and early '99, I dont want to mes this up and have to buy a new one for $300. Thanks.
Old 12-05-2009, 12:59 PM
pretty sure u can only buy the whole hub assembly.
Old 12-05-2009, 01:04 PM
I have the bearings from NAPA, just need to get it apart now.
Old 12-05-2009, 01:30 PM
Well I've never heard of just changing bearings. I've always had to change the whole thing. Good luck and if you do. Chime in and school us please.
Old 12-07-2009, 07:14 AM
Wink sorry
you cant change bearings i have tryed this all your gonna do is break houseing or break press the only way to remedy this problem is to order the dyna track free spin kit then you can replace bearings i got mine for $1200.00 and you get warn premiem hubs and 35 spline axles easy to install to have to look around web to find um cheaper than what dyna track sells them for just make sure you plug your air lines going to old hubs
Old 12-09-2009, 11:20 AM
You can replace the inner bearing where your axle shaft goes, but if its the big outer bearing, your SOL.
Old 12-09-2009, 11:34 AM
Well after much research, I found out that NAPA gave me the wrong parts and I ended up getting a whole hub (Timken) for a late '99 and a late '99 rotor both for under $200. All is well now, thanks for all the replies.
Old 12-15-2009, 05:25 AM
FYI for all the early 99 owners I found a place selling Timken early 99 hubs for $150 plus shipping....
Old 01-17-2010, 03:56 AM
can you give a link to the place selling these hubs? I need two!
Old 01-17-2010, 04:52 AM
99 1999 Ford F350 Super Duty Wheel Hub Assembly - Driveshaft & Axle - FEQ, Timken, Replacement, Front, Left - Driver Side, Right - Passenger Side - PartsGeek
Look at the bottom of page, glad I could help
