front hub assembly - Ford Powerstroke Diesel Forum
post #1 of 23 Old 11-11-2009, 04:46 PM Thread Starter
Leeville Outlaw's Avatar
front hub assembly
I have a 02 f350 4x4 dually and the bearings in my front hub assembly are good but the bearings that support the axle is gone. the bearing farthest out on the axle has a plastic gear on it that melted when the bearing went out. can you replace these bearings without buying the whole hub assembly?
Leeville Outlaw is offline
post #2 of 23 Old 11-11-2009, 04:48 PM
Tony V's Avatar
Pretty sure you have the buy the whole thing. it sucks
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #3 of 23 Old 11-11-2009, 04:50 PM
choupique108's Avatar
you have to buy the whole hub assembly. its like 300 bucks
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #4 of 23 Old 11-11-2009, 04:51 PM
Tony V's Avatar
you can getem on ebay for 120ish. Quality prob not as good, but works.
Tony V is offline
post #5 of 23 Old 11-11-2009, 04:56 PM Thread Starter
I just got back from Oreillys n they have the bearings for just the axle but I still need the plastic gear on the lockin mech any ideas. o the bearings were only 8 bucks each
post #6 of 23 Old 11-11-2009, 04:58 PM
What bearing are you talking about? The one in the lock out? or the little one thats built into the main hub assembly? I just had the little one thats built into the main hub assembly go out and i just replaced the little one. i did both sides because the other side wasnt to far behind. When mine let loose though it took out the lock out also so i just bought a set of warns.
Alex
Early 99 F350 4x4 crew cab long bed
-d66 turbo
-5" stack
-diy intake
-bully dog 6 pos.
-leveled with 35's
stroked383 is offline
post #7 of 23 Old 11-11-2009, 04:59 PM
Tony V's Avatar
Well I dont think you are holding the right bearings. I've never heard of anyone changing these with out doing the hole thing. Good luck.
Tony V is offline
post #8 of 23 Old 11-11-2009, 05:00 PM
Im almost positive you cannot buy the bearing in the lock out. And f.y.i. warn lock outs are cheaper than factory replacemints fronm the dealer.
Alex
-d66 turbo
-5" stack
-diy intake
-bully dog 6 pos.
-leveled with 35's
post #9 of 23 Old 11-11-2009, 05:07 PM Thread Starter
They are the exact bearings I just miked them I was hopin i could just replace the plastic gear in the lock assembly its the gear when u pull the big snap ring and pop out the lock assembly its the first thing u see
post #10 of 23 Old 11-11-2009, 05:07 PM Thread Starter
does the warn do away with the vacum
