Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
  #11 (permalink)
Old 11-06-2009, 11:04 AM
adfields adfields is offline
Originally Posted by 66Bronco View Post
That's what I'm saying. You can't put an actual locker over a limited slip.
But do you know why? What is different about the carrier?
I have only ever found reference to 2 different 10.25 carriers, one for with the speed sensor and one for without it. I have never been in a 10.25 limited slip but have been in 8.8s, 9s, D44s, and D60s and am wondering what is different about a 10.25, I like to know the reasons for things. I was told by many that I could not put a Powerstroke in my 76 body but because I ask why there she sits.
  #12 (permalink)
Old 11-06-2009, 05:15 PM
66Bronco 66Bronco is offline
Mainly because the limited slip carrier is setup different, i.e., the gear spacing would change if you were to put a locker onto a limited slip (a couple thousandths). Also, there's no guarantee that either would work as expected if at all.
  #13 (permalink)
Old 11-07-2009, 01:53 AM
What I don't get is when you install a locker you pull the carrier out remove the ring gear, stator ring, and bearings if you want to reuse them. Install the ring gear, stator ring, and bearings onto the locker and bolt it in with the caps. Since the locker is its own carrier I don't get why it would matter.
  #14 (permalink)
Old 11-12-2009, 07:59 PM
Shack in Nac Shack in Nac is offline
Replaced carrier...broke this one too..
I replaced the "chunk" or carrier unit..bought a used one...ran it today..seemed to roar,,,I took out the fill plug..had a piece of ring gear on it..took cover of..all my gears on the ring gear are broke 1/4 to 3/4 inches...I am not sure what to do now...used parts the prob?? or ???? I now need a new carrier and gears I guess..just knew I had it fixed....
Shack
