Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 11-02-2009, 10:11 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
weird noise, shaking
ok i was going down the road today and when im in full throttle there is a terrible shudder (thought it was a tire till i got out the throttle and it stopped) and when i get out of the throttle and coast i hear a really weird squeek noise till i depress the clutch then the shaking and squeek are gone...
truck is a early 99 7.3
new trans 2k miles
new pilot bearing 2k miles
new con fe clutch and throwout bearing 10k miles
other than a boost fooler i am bone stock
Old 11-02-2009, 10:53 AM
WE ARE DOOMED
Tournaments Won: 1
ok ujoints are great but the drive shaft in the carrier bearing moves up and down about 3/4" up and down and side to side i believe i just located my problem what do you guys think
Old 11-02-2009, 11:08 AM
JakeLewis79 JakeLewis79 is offline
the driveshaft is turning whenever you're rolling, so it should still be doing it even if there isn't a load on the engine. But it would probably be less noticeable. Let us know how it goes.
Old 11-02-2009, 11:09 AM
mbahr22250 mbahr22250 is offline
I had a carrier bearing go out on my last truck. It shook so bad I thought a wheel was coming off. Plus it made a terrible noise, not really a squeek, more of a growl. The bearing will move a little in the rubber isolator though so make sure that isn't it, but it sounds like it's probably bad.
