Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 11-02-2009, 10:03 AM
JakeLewis79 JakeLewis79 is offline
Ball Joint Grease Zerks
WTF? I was just under my truck with the grease gun to do some maintenance. I had my ball joints replaced and all but the driver's side upper ball joint have a grease zerk. It does have what looks like a small bolt there instead of a grease zerk. Can I replace this bolt to install a grease zerk?
Old 11-02-2009, 10:06 AM
choupique108 choupique108 is online now
In search of 20s
Location: Lake Charles, Louisiana (currently Shawano, WI)
yea you can but after you grease it i reccomend putting the bolt back in. My ujoint broke one of my zerks off and now i have to find a way to get whats left of it out
Old 11-02-2009, 11:52 AM
bens99f350 bens99f350 is offline
I put the 90 degree zerks in mine... just ground off a little of the material that may or may not get hit by the u-joints... been working just fine!
Old 11-02-2009, 01:10 PM
scotty2280 scotty2280 is online now
yep mine hasent broke with the 90 zerk. its close thou!
Old 11-04-2009, 11:22 AM
In search of 20s
i had the 90 degree fittings too and it broke it. i may try grinding it down a little bit next time i put one in there
Old 11-04-2009, 01:49 PM
NoRalPh NoRalPh is offline
I remove the plugs on my uppers and temporarily install a 90 degree to grease. Then, remove the 90 and reinstall the plug. I tried to grind a 90 down but, it was just So Close I didn't dare leave it because if it broke off I'd be screwed and not able to continue to grease at All...
I've gotten pretty good at it and it only takes a couple of extra mins and I'm Sure worth it!
