- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Sponsored Links |
Yes, brand new bearing assy. As for the manual lock hubs I did not replace them. I checked for pitting in the shaft but there wasn't any. So I just assumed the bearings had been wore down evenly without damage to the shaft. Basically was just wondering if someone else wouldn't mind popping a hub off and checking the play in their outer shaft and see if it is similar or there is no play at all.
You can re use your seels the pilot bearing is most likely the problem had the same thing happen to me and kept driving it until it damaged my axle. Lock your front hubs and see if the problem stops. If this works its most likely the bearing now heres the good news its a dealer part that they only will sell you with a complete hub assembly but I discovered that NAPA has the bearing for $13 hope you didnt damage your axle. Good luck Steve |
Diff oil level is correct just had them check for me during my last oil change less than a week ago. When I say I had it in 4x4 I mean by actually locking in the hubs manually. I don’t believe I have auto locking hubs. I know that when they are manually in 4x4 it still makes the same noise. I’m so confused on this one…….
Anybody have a chance to remove thier hub and check the shaft play for me?
| Sponsored Links |
