Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 06-24-2009, 08:23 PM
BLACKHOLEBANDIT BLACKHOLEBANDIT is offline
carrier bearing drop?
i got 01 f350 cc lb with 9in lift and i got pro comp carrier bearing drop but it still got vibration at take off how much drop do you think i need?
Old 06-25-2009, 11:23 AM
caryt caryt is offline
Usually they won't help you can get a CV DS that will cure it
Old 06-29-2009, 12:33 PM
lcducote lcducote is offline
might be ur u-joints on the vibe... just throwin an idea at you. good luck
Old 06-29-2009, 12:36 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
you running blocks in the rear? you sure its not axle wrap? when do you get the vibration?
