tach not working - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-25-2009, 08:42 PM Thread Starter
97bluestroker's Avatar
Send a message via AIM to 97bluestroker
tach not working
Randomly, this morning, my tachometer decided it wasn't going to work. I recently changed my gauge faces on my dash but everything has been working fine. I've already checked the fuse... any suggestions or ideas? Any guidance would be great!
'97 F250 HD PSD, 4x4, Auto, Ext Cab, LB, 4" Lift, Tint, 80/120 hp DP Tuner, Straight Piped, AFE Stage 2 Air Intake w/ Pro-Guard 7, Aftermarket Intercooler, SpecRite Dual Disk Torque Converter, Pumped Up Tranny w/ Transgo Kit, MagHytec Deep Tranny Pan, Pyro, Boost and Tranny Temp Autometer Gauges, Pro Comp Adjustable Shocks, 305/70/16 BFG Mud Terrains on Weld Rims, Spray on Bedliner, Flip Down DVD Player
97bluestroker is offline
post #2 of 2 Old 02-27-2009, 05:55 PM
ricksstang's Avatar
Tach no workey
The tach gets its power from the same fuse and has the same ground as all the other gauges.
So if it is the only gauge not working there are only two other things in the system. The Tach and the PCM.
So lets hope that it is the tach. Its the only thing that makes sense.
Rick
Dirty South Strokers
95 Crew Cab Dually PSD
3"dp into 4"exhaust
Gauges: Boost, Trans Temp, EGT
K&N Intake
Performance built Trans
Edge EZ
ricksstang is offline
