Need help 7.3 P/S shut down won't start back - Ford Powerstroke Diesel Forum
Old 02-19-2009, 06:01 PM
96 F-250 Powerstroke Shut down in the road and won't start back.... Any ideas? Thanks, Bill
Old 02-19-2009, 06:14 PM
duct tape & zip ties
could be a cps, or something else. Need to scan for codes.
Old 02-19-2009, 06:24 PM
does your tach move you crank the engine?? if not, your CPS is dead. $30 at the dealer and a few minutes to change.
Old 02-19-2009, 06:28 PM
Jon
Guest
Posts: n/a
Check the maxi fuse under the hood that covers the fuel bowl heater and the pcm relay. If its blown disconnect the fuel bowl heater on the side of the fuel bowl and put a new fuse in it.
Old 02-19-2009, 06:40 PM
I just went out and spun it over.... And the tach is working as it spins
Old 02-19-2009, 07:08 PM
Shut down won't start
Checked all fuses, None bad, Bowl full of fuel, Warm up light comes on, Its spinning Fast enough to start, but will not fire.
Old 02-19-2009, 07:13 PM
Can you get a hold of a scanner and check for codes?
Old 02-19-2009, 07:23 PM
Not to sound stupid but check ur oil make sure its not low low oil shut off,or could possibly b cps.
Old 02-19-2009, 07:24 PM
A buddy of mine works for volvo truck, I'll try to get him to come by the shop and check it, Thanks for the help... Bill
Old 02-19-2009, 07:25 PM
Keep us posted Bill so we can help ya out with your issues.
