Fuel leak? - Ford Powerstroke Diesel Forum
Old 02-12-2009, 03:56 PM
Fuel leak?
ok hey guys i am haveing some fuel leaks it is filling up the vally on my motor and leaving some puddles any help here i already fixed the leaking fuel bowl heater thing????
Old 02-12-2009, 04:02 PM
Send a message via AIM to pwrstrokinrebel
it could be the fuel bowl drain valve that was leaking on mine a few weeks ago
it is the yellow handle valve on the turbo side of the bowl
the o rings srink up and cause it to leak
Old 02-12-2009, 04:11 PM
could you see the leak? and how did you fix that
Old 02-12-2009, 04:18 PM
i first noticed it leakin on the ground mine had a hose hooked to the valve some my not but the valve is held on the fuel bowl with for star bit screws.....
you can get the valve at the ford dealer for around $30 it is a lot easier than just gettin the o rings
Old 03-15-2009, 07:32 AM
Send a message via AIM to USMC97stroker
I had fuel leaking down in the valley also, look on the right side of your fuel bowl housing, there is a water in line sensor that screws into it, the black plastic will sometimes crack resulting in a steady fuel drip when under pressure, the sensor retails for about $40 on dfuser.com
Old 03-15-2009, 04:42 PM
ADMIN AND TECH
which truck year model are we atlking here , depends on we are talking the old body style or new body style, i see both years in your sig
Old 03-15-2009, 05:44 PM
well im talking about my 97, but i do believe that all the 7.3's have a water in line sensor
Old 03-15-2009, 05:49 PM
<<---"Shadow"---
He was questioning the original poster- not you, but thanks.
