96 ELECTRICAL - Ford Powerstroke Diesel Forum
Old 02-05-2009, 05:00 PM
96 ELECTRICAL
Have had a problem with left turn signal. It has caused the cruise control to turn off for awhile now. Just noticed that it seems to change rpm slightly at medium speeds. Have looked at the multi switch turn signal but I don't know what wires are what.
Old 03-22-2009, 04:13 PM
I had the same problem with mine. Also the power window switch was intermintent and the hazards were not working. I removed power window switch assembly, pulled switch cover off and sprayed a product called DEOXIT on the contacts for the switch, reinstalled and it works great now. With the hazard and turnsignal I just douched the switches with DEOXIT and worked the switches, let it sit for about 2min then douched again. Everything works like a champ now.
